Jet force zu Vergaser
hallo Jungen können zu Vergaser das Jet force tsdi bekehren?
wenn sich wie man macht?
warum benutzt es den gleichen Block Motor des Jet force c-tech..... auch Federball?
______________________________________________________-
jet carburetor force
hi boys the jet force carburetor tsdi can be converted?
if him as he does?
because it uses the same block motor of the jet force c-tech..... also badminton?
if him as he does?
if him as he does?
if him as he does?
