Fuel Pump
    4.1 Sterne bei 42 Bewertungen. 5
    • Hi all,
      Im new here but I'm trying to sort out a Jetforce 50cc. It threw a lot of codes (10 in all) all linked to the fuel supply chain (pump, air injector, 4x potentiometer, etc) but starting with the most obvious the fuel pump. It was not priming at start up and once removed and dismantled the motor is shot. I can get it to run but only by manually spinning it with power applied. Even then there is not enough power or speed (in my mind) to pump and sustain upto 8 bar.
      As a whole unit this turns out to be a very expensive part and not that available.
      Research and including feeds on this site demonstrate that this part is a real pain.
      So I have two questions
      1) Can I swap it out for a totally different 3rd party pump? If so what are the suitable alternatives?
      2) can I buy a new motor only.
      searching the web does not throw out any immediate answers.
      cheer all
      David
