Hi,
könnt ihr mir das bitte übersetzten?
Danke schonmal im vorraus!
Achja, es geht um ne CDI von ner Iro.
r.cupheizzaPut the RJ051X MVT diagram at the original CDI place. For the models with a Dellorto ACPH1 CDI, use a RJ054X diagram, put the red clip on the black cable of the CDI without disconnecting it. Put the brown cable not bared in parallel of the black on the clip and close the clip with pliers in order the 2 cables are joined in parallel without cutting the black cable of the diagram. Disconnect the high voltage coil cables. Connect the black cable on the green connection of the original high voltage coil and the orange cable on the black connection of the high voltage coil. Connect the second black cable of the diagram to the earth frame, with green/yellow of the stator. Connect the black/red cables of the stator and of the diagram together.
JetForceDE hatn Stück von nem Messer in seiner Vario !
 ja ich habe schon geguck aber ich finde es nicht .. soll ich mit nem staubsauger saugen?
